Here you’ll find answers to the most common WOLFBOX dash cam questions — from installation and setup to troubleshooting and firmware updates.
This post helps you solve issues quickly before reaching customer service.
This page lists the most common product-related questions collected from users and our customer support team.
Please note: the community does not provide live customer service.
For after-sales requests, warranty, replacement parts, or detailed product specifications, visit our Support Center.
You can also explore more model-specific FAQs here or Contact Us directly to register your order or reach our support team.
🛠 Installation & Setup
Q1: Where should the rear camera be installed? A: Mount it at the upper center of the rear windshield for a clear view. For models with an external waterproof rear camera (such as the G900 and T10 series), secure it firmly and keep it away from wipers or defroster lines.
Q2: How can I hide the power cable? A: Route the cable along the windshield edge and inside the A-pillar trim, tucking it under the rubber seal. Avoid airbag areas. Connect it to the cigarette lighter or a hardwire kit.
Q3: Do I need a professional for hardwire installation? A: It’s recommended. A qualified technician can avoid miswiring the fuse or unstable voltage issues.
Q4: Can I extend the rear camera cable? A: The original rear camera cable is about 6 m long (8 m for some models like the G900 and T10). Extension is not recommended, as it may cause signal loss or interference. If you need additional length for longer vehicles, please contact WOLFBOX Customer Support to purchase the official extension cable.
⚙️ Features & Settings
Q5: Why can’t I connect to Wi-Fi? A: Ensure your phone connects to a 2.4 GHz network, disable mobile data while pairing, and grant all app permissions.
Q6: Why are old videos overwritten automatically? A: Loop recording is enabled. When the SD card is full, the oldest files are replaced. Videos locked by the G-Sensor or manually are less likely to be overwritten, but storage space is still limited — they may eventually be replaced if the card is full. We recommend saving important clips to your phone or computer for long-term storage.
Q7: Parking monitoring doesn’t work. What should I check? A: Ensure the hardwire kit is properly installed with ACC and B+ connected, and the Parking Monitor feature is turned on in Settings. Select the correct mode (Motion Detection, Collision Detection, or Time-lapse) based on your model.
Q8: Can I turn off the screen while recording continues? A: Yes. Enable Screen Saver or Screen-Off Recording in Settings. (Some earlier models only support Screen Saver, not full screen-off recording.)
Q9: Can I view videos in the app? A: Yes. Connect your phone to the dash cam’s Wi-Fi, open the WOLFBOX App, and you can view, download, or manage recordings. (Available on Wi-Fi-enabled models such as G840S/H, G850, G900, T10, and T700. If the app fails to reconnect, forget the hotspot and reconnect manually.)
Q10: There’s no sound in the videos. A: Check if the Audio Recording function is off or the microphone is blocked.
Q11: How do I format the memory card? A: Select Format SD Card in the system menu, or use a computer to format it to FAT32 (recommended). While exFAT is supported on some models, compatibility can vary — for best stability, use FAT32 whenever possible. For cards larger than 32 GB, you’ll need a dedicated formatting tool to create a FAT32 partition.
🔌 Accessories & Compatibility
Q12: What size memory card is supported? A: Use a Class 10 or higher MicroSD card. Most models support up to 256 GB, but some earlier models (such as the G840 series) are recommended to use up to 128 GB for optimal performance. Format the card before first use and regularly (about every two weeks) for best results.
Q13: Is a CPL filter necessary? A: It helps reduce glare and reflections from the windshield—ideal for bright daylight driving.
Q14: Can the GPS module work on its own? A: No. It must be connected to the main dash cam to record speed and location data.
🧩 Firmware & Update
Q15: How do I update the firmware? A: Download the correct firmware for your model from the official WOLFBOX website or support team, copy it to the SD card root directory, insert the card, restart the device, and the firmware update will start automatically.
Q16: How can I check the firmware version? A: Go to Settings > About Device to view the current firmware version.
⚠️ Troubleshooting
Q17: Why do my recordings stutter or drop frames? A: The SD card may be too slow or fragmented. Use a high-speed card and format it regularly.
Q18: The dash cam froze—what should I do? A: Press and hold the power button for 10 seconds to force a restart. If it happens often, update the firmware or replace the SD card.
Q19: Why does the dash cam start slowly? A: It may take time to initialize the SD card or the input voltage is low. Use the original WOLFBOX power cable for stable startup.
🧾 After-sales & Warranty
Q20: What is the warranty period? A: 12 months from the purchase date. Non-human damage is covered for free repair or replacement.
Q21: What should I do if any parts are missing from my package? A: Take photos and contact WOLFBOX Customer Support for verification and replacement.
🌍 Other Common Cases
Q22: GPS coordinates in the video are inaccurate. A: GPS accuracy may vary due to weather or obstructions. Test in open areas and ensure the firmware is up to date.
Q23: The night video is too bright or too dark. A: Enable HDR/WDR or adjust the exposure value manually for better balance.
Q24: The date or time is incorrect. A: Adjust the time zone manually in Settings, or enable GPS Time Sync if your model supports GPS.
Q25: The dash cam shows “SD Card Error.” A: Reformat or replace the SD card. If the issue persists, use a high-speed Class 10 U3 card.
Q26: How can I turn off voice prompts or beeps? A: Go to Settings > Sound > Beep Sound and turn it off.
This FAQ is continuously updated based on user feedback and firmware changes. If you can’t find the answer here, please visit the Support Center for direct assistance, or check the Model-Specific FAQ for details about your dash cam series.
